stanmitchel
stanmitchel
Problème de toit et bruit dans le coffre lors de la conduite sur des pavés Empty Problème de toit et bruit dans le coffre lors de la conduite sur des pavés
Message par stanmitchel Jeu 21 Avr 2022 - 19:40
Hello everyone, I recently bought a Peugeot 206 CC 2003, after buying I found problems with the roof
The roof opens only when a person presses on the rear of the trunk
There is also an unpleasant problem with the sound when you drive along the paving stones, an unpleasant noise from the trunk, as I understand it, this is the plastic part of the roof opening mechanism, which beats against the metal part of the body
I'm sure it's common, but I can't find a solution
Problème de toit et bruit dans le coffre lors de la conduite sur des pavés Empty Re: Problème de toit et bruit dans le coffre lors de la conduite sur des pavés
Message par pascoual Jeu 21 Avr 2022 - 20:08
Try to disconnect the trunk locking.
Here
If it works, you just have to adjust the locker.
Surprised, thought it was war in your country ! And you're worried about a roof problem ?
stanmitchel
stanmitchel
Message par stanmitchel Jeu 21 Avr 2022 - 20:24
@"паскуаль" Thanks, I'll definitely try
The war has been in my country for 8 years, we need to continue to live =)
f1.jeanphi, pascoual, seb69 et co-pilote aiment ce message
stanmitchel
stanmitchel
Message par stanmitchel Ven 22 Avr 2022 - 15:41
Okay guys, now I have a big problems
I tried to open the roof
trunk raised a little and the roof stopped opening
Then the trunk closed itself, but while driving, I hear a sound notification about the problem
And when you try to close or open the roof, such a sound
stanmitchel aime ce message
Message par seb69 Ven 22 Avr 2022 - 16:25
When you're remove the hooks can you use the windows?
stanmitchel
stanmitchel
Message par stanmitchel Ven 22 Avr 2022 - 16:27
[Vous devez être inscrit et connecté pour voir ce lien] no, i can't
stanmitchel
stanmitchel
Message par stanmitchel Ven 22 Avr 2022 - 18:53
I WON THIS ROOF!!!
I found the right position and it opened all the way, after which I disconnected the wire from the trunk lock and it now works great!!
How do I understand I need to buy a new trunk lock?
seb69 aime ce message
Message par seb69 Ven 22 Avr 2022 - 20:16
:non:
you're looking at the trunk door strike on the pillar. 2 torx 30 screws. You put together a few millimeters upwards and it will be good Wink
